225VA for FW clone
I put J2 and M2 in the same chassis using talema encaps 2x18V 225VA, locate them on each corner of the room intended for monoblock. with neutrik powercon, I can choose J2/M2 to play. but I rarely use it because SIT L'Amp mostly used for fullrange driver
with 3way dsp project, I'm using 2 class ab amplifiers for midrange and tweeter operating above 200Hz.
if i want to use this unused J2/M2 for mid+tweeter in 3way speaker, just wondering is it wise to power both J2 and M2 with only 225VA toroid? will it make toroid become too hot or both amplifier got less amperage? not sure which one or both will happen
finally took my time to re wire, J2 for Satori and M2 for Dyn MW152, another aragon2004 for Dyn 24W100, managed by ARC car dsp. have not utilized umik1 for measurement yet, just tune by ears.
i was wrong to think that 25W class A "might" not enough for 4ohm car drivers, had a thought to buy Aleph2 board, but in fact so much extra potentiometer available for this small FW clone.
watching 4k movie is so much fun with class A, the vocal get "hotter" 😁
Reactions: uncola and manniraj
