What’s this subs 8omh RMS?
I got this amp it’s says 1200w Max blah blah…
The actual rms is 2x
200w for 2omhs
I got a sub coming that’s 200rms 400max
It should be fine, the amp got 2 speaker outputs and it’s 2-16omh amp, could I run my sub from one speaker output and my 4x30rms watt 3way coaxial 4omhs speakers from the second channel?
Running the coxial speakers at 8omhs will make them take 60rms, just not sure can’t find the amps 8omh load rms but am guessing from the image above it’s somewhere 70watt at 8omh
Please correct me if am wrong
This is for home project I already am running my coxial speakers with a cheap amp.
