Amps that use IRS21844s chips
Couldnt amps that use 2 or 4 chips get by with just using one chip? If i ran jumper wire from the output of one chip the the output pads of the other chip locations would that work? What's the benefit of giving each inductor its own chip? Is it just allowing there to be less components running in parallel?
