Friends,
I have finished the design of the soft start scheme for my dual mono amplifier Q17, where 2x 500W toroidal transformers will be used. The main switch will be on the rear panel.
Sorry for the ignorance, l can't find the power switch in the circuit, how do you turn on the amps? And what are the two relay for? Would you explain how the circuit works?
