How to remove a dustcap
Joined 2008
Here in pictures if you ever wondered how to remove a dust cap without damaging a driver.
With this tweak I changed a "bass driver" to a fullrange driver. Got approximately +4 to 5 decibels above 1.5 kHz.
The aluminium voice coil emanates a lot of good high frequencies usually getting lost being buried by a dustcap.
I use further dsp correction together with a current drive amp to lower distortion and get linear response.
Usually I cover both sides of the diaphragm with aluminium foil to get a sandwich cone as DIY "for free"
Reactions: AllenB
Or you form a metal dust cap and put it directly onto the voice coil.
From measurements I know you lose some decibels on axis again but you gain some decibels out of axis as a dome emanates with wider dispersion than leaving it completely open.
If you want to keep it simple just leave it like this. Beaming in the highs can be lessened with indirect reflecting tweeters behind the box, the sides or on top.
Here is important that the side tweeters should strictly work only above 5 kHz. Then the imaging of the fullrange driver is not disturbed.
Steep filter 18db or tweeters with natural steep fall below 5khz should be used.
The 5khz rule for side tweeters could be learned about from Peter Pfleiderer (who constructed the FRS20 fullrange loudspeaker with three side tweeters, I have a pair of them).
In his book "Lautsprecher auf den Punkt gebracht" he refers to Werner Haas (giving Name to the "Haas effect")
https://de.m.wikipedia.org/wiki/Haas-Effekt
I needed several tests for making a loudspeaker sound OK with side tweeters. They should have narrow dispersion as they should not interfere with the main driver which is important for imaging.
Peter Pfleiderer achieved intended directivity control for side tweeters using old type 5cm tweeter with paper cones and lowering them into the enclosure by mounting them from the backside of the wood of the box (like in old boxes). Works well.
