This capacitor-diode series combination is from a Sherwood RX-4010R receiver that I am recapping. I believe this Sherwood was manufactured sometime around 1993. Apparently these parts were a factory change that was added on (the cap is the same type used throughout the unit). The parts are undocumented, they do not appear anywhere in the Service Manual.
The diode has the marking " Z3.3" on its body. So I would assume it is a 3.3 volt zener. But the way it is used in circuit, it makes no sense to me that a zener was needed.
Is there any way that the "Z3.3" marking might possibly NOT indicate that it is a 3.3v zener? I just want to replace both parts with original equivalents.
Thank in advance...
Thank in advance...
- Design & Build
- Parts
- Can anyone identify this diode?
