Internal switch in Krell KSA S-series to power on and off via AC wall outlet
Hello
According to the Owner Manuals of the Krell power amp KSA S-series there is the possibility to switch it into a Remote Turn On Installation. Meaning that the Krell can be switched on and off by an AC power outlet with a mains switch and bypassing the On/Off-switch on the front plate.
To make this change something has to be done in the inside of the Krell (little switch?). Does anybody know how the Remote Turn On Installation can be done.
I want to hide the amp and switch it via the AC wall socket.
Yes, there are two switches inside. The red micro-switch in the right is for "power up" option (manual or mains) and the other micro-switches for "unit select".
I think it's best to contact Krell for assistance.
https://www.krellhifi.com/contact/
