Great place here, have not posted for ages but I've had lots of useful info as I'm getting into CD players.
The Marantz CD65 II SE is said to use the 4/19 composite mechanism (metal and plastic I believe), whereas the CD65 II (and many others) use the standard 4/19, plastic only.
Can these be swapped? If I get a SE model I'd like to be able to fit the more common standard plastic one if necessary, even if there is a slight drop in performance.
I have searched but can't find the answer; it may be a silly question but better to ask!
I am considering having a CD65 II SE modded and converted to NOS, then I'd lampizate it myself.
