VFET headphone amplifier
using any of recent Papa's VFet amps for headphones:
- no need for gain stage, but some sort of buffer is needed, to properly drive OS; one idea - use FE having JFet buffer and xformer, but shorted (or just cap) instead of xformer
-take care of inserting some sort of power-on delay circuit for headphones, due to inevitable thump uring power on; with speaks that's not problem, it can kill headphones
now, if intended schm is posted here, I could write more
without it, I don't want to risk broken telephones scenario
Converting any amp to headphone amp is just a matter of two resistors on the output. I used to do it for low power tube amps.
Why use 10watts power amp as headphone amp? When 10 milli watts is used?
When Whammy or ACP+ are available?
Vfet will require large heatsinks, high bias and will burn close to 100watts of idle power (~1.5A per channel at 24VDC).
Still easy to ask in vfet builders thread.
Here is what I am going to do :
  • build the 2 VFET kits
  • use the FE card from the vfet part 2, short the xformer
  • use a velleman k4700 kit to prevents switch-on clicks and DC components on the output
  • use 2 SMPS DC Filter P089ZB Kit and 1 Mendel Meanwell 36v SMPS
I have 2 last questions:
Many thanks
This was the resistor complex from the Sony TA 4650 that connected the VFET amp to the headphone output:
