Cary SLP-74 Preamp
I have Cary Audio SLP-74 tube preamp that uses (2)12AT7 tubes and (2)12AU7 tubes but I forgot which tube goes in which socket.
Sockets are V1,V2,V3 and V4. I can't find anything in the owner's manual or on the circuit board that tells me. Any help much appreciated.
CMS2469, I can see you've already figured it out (valve position).
I'm repairing a Cary Audio SLP-74 and I believe it has been tampered with in the PSU.
would it be possible to send me some info and/or photos of the PSU?
Those bigger caps in the photo they are 4x47uF/350V and 2x100uF/350V? when in stand-by those caps get about 400V, and thats not heathy! either the PSU is not OK or I need to replace those caps with 450V ones.
Can you help me in any way to get this preamp into original shape?
