Sony PS-2250 Startup current draw issue
Looking for help/suggestions.
I've got a Sony PS-2250 that is blowing the 200ma fuse on startup. Running it through my multimeter, it is drawing about 320-340ma for half a second (both 33/45 startup) and then drops to about 100ma after and runs stable. I've replaced all caps and transistors on speed control board and one bad zener and checked all other resistors/diodes. All is good. The thermistor was pulled and seems in spec and working (120 Ohm @ 25C, rise/lower with temp change), but I will order a new one. The encapsulated component (120 Ohm/0.033uf) I think is good and my understanding is this just filters switch noise and not the cause.
I'd rather not just drop in a 400ma fuse and find a better fix.
Would anybody have an idea?
The SM doesn't mention slow blow fuses, and I did not find anything about using them with the TT. It would be a fallback plan. Everything else seems to be fine now with the table, and after testing through multimeter, I popped in a 500ma fuse I had on hand to test with until I get a slow blow or a better solution. The power transistors seems fine, but wonder if it could be the cause? I have pulled, tested and redid thermal paste when reinstalled.
I think I have my answer.
While the SM did not mention slow blow, on the chassis it is marked 200 mAT, so I take the T to be time delay which makes sense for the behaviour I'm seeing. Happy not to need worry about using them now.
