Hello.
I have too much units on the shelf and some of them has to go:
Audiotechnology 18H52/17/06/SD 4 Ohms SOLD!
Original boxes. Very good condition. 100 to 150 hours of carefully use only in HiFi. Connection terminals not soldered
T/S Parametar taken with DATS V3
D 130 [mm]
Re 4.126 [Ohms]
Fs 44.88 [Hz]
Zm 23.81 [Ohms]
BL 8.519 [N/A]
Qms 1.86
Qes 0.3897
Qts 0.3222
Vas 12.8 [liters]
L10k 0.05936 [mH]
n0 0.2831 [%]
Ms 24.31 [grams]
Cms 0.517 [mm/N]
D 130 [mm]
Re 4.126 [Ohms]
Fs 44.88 [Hz]
Zm 23.81 [Ohms]
BL 8.519 [N/A]
Qms 1.86
Qes 0.3897
Qts 0.3222
Vas 12.8 [liters]
L10k 0.05936 [mH]
n0 0.2831 [%]
Ms 24.31 [grams]
Cms 0.517 [mm/N]
