Stereo balance
If this is an amplifier, you should preferably fix the circuit problem instead.
Can you post the schematic? Tube or transistor?
But if you have to add a balance control at the inputs, use a linear pot with the wiper grounded.
Then series resistors in each channel before the pot allows a voltage divider action to change
the relative output voltages.
