Repair Question
I’m rebuilding an 8K amp .
The outputs are drivers survived .
The only damage I see is the power supply fets and drivers .
All the gate resistors for the fets are within tolorance I checked them at room temp I did not hear them nor cool them to see if the drifted out of tolorance .
Wondering is it a good practice to replace the gate resistors when replacing the fets and drivers ?
Also is there anything else that should be replaced when I’m in there in the power supply section since some parts get stressed when the fets blow .
I’m asking this since this amp is going back into a competition vehicle and need it to be reliable.
The original drivers are A1275 and C3228 for the power supply .
I don’t have enough bd139/140 on hand .
Would the mje171/81 or the mje172/182 work as replacements since I have both on hand
This 8K amp is the same design as all the other clones out there using these drivers /fets
I also noticed this resistor what would cause this ? And would it have anything to do with the power supply fets shorting ?
