Driver at top or down 1/3 in 1:1.618 big sealed ?
I am a firm believer in 1 x 1.618 ratios………….
So let’s make a box, say 33” tall x 20” wide x 13” deep………….
Has anyone measured or heard a difference when the driver is roughly 1/3 from the top dimension versus at the top ?
On more of a pencil, or mltl design, absolutely, anything column-like, where 2 dimensions are fairly close, then the 3rd dimension is 2-3 (or more) times larger, pipe-ish basically, I can see offsetting the driver, even seen the measurements.
My thoughts are it wouldn’t matter much on this big sealed 1 x 1.618 x 2.62 ratio box.
Whatcha think ?
I don’t think placement (as long as not too close to a wall) will have little affect inside, but outside it will.
Not sealed but why not place driver also using the golden ratio?
This one not as big as yours (17 litre net, maybe 18-19 if it was sealed)
http://www.planet10-hifi.com/planset/fatCGR-extents.pdf
Bur i am working on a 35 litre one for things like Alpair 12pw, maybe CHN-110.
dave
Reactions: NeonDriver
From what I've read, I'm aware of three notable ratios for an enclosure...the so-called Golden ratio 0.618/1.0 /1.618 the ever present 0.707/ 1.0/ 1.41 and another 0.7937 / 1.0/ 1.2599 Now, I've been told this last one is mathematically derived & should not be used.
As to driver location upon a panel say X by Y, 0.618(19.776 inches) and 1.0 (32 inches) ...the folks at the baffle step camp I'm thinking will say NO to an exact center as frequencies will be multiplied together because of the same distances to the edges .. But I'm betting these fractions 0.618, 0.707 and 0.7937 should make for good locating points on a front baffle. My two cents...
---------------------------------------------------------------------------------------------------------------------------------------------------------------------Rick...
It comes from an old industrial design ratio for rectilinear proportions -they don't appear visually 'pleasing' until one ratio is at least 1.414x that of the other. What I've often thought is that the 'at least' bit can get overlooked. That said, in many instances the wavelengths involved are relatively short and easily damped out so it's often not too big a deal, though better avoided or slightly modified, as Dave says, which usually isn't too difficult as it doesn't need much of a change.
