Loudspeaker protection flawed design?
Hello.
I'm building a p3a amplifier and bought this speaker protection kit, but after assembly it struck me that something is wrong.
It has a perfect 2 sec delay after power up, but if you look at pictures you will see only in and output from relays, so in my opinion the board cannot detect any dc from amp at all, it needs a ground reference.
Am I wrong? I can hook up a wire from it's own psu ground to my amp ground, would it work?, also I'm doing the p3a as dual mono, and I'm afraid this new ground might cause loops, I've been using hifisonix pdf on dual mono grounding.
What is best approach? My two psu grounds have each 10r and a parallel 100nf to chassis ground
Thanks guys, yes r7 is 22k , but if you look at the picture, the board has it's own transformer and regulation, and there is absolutely no connector for amp ground.
A novice like myself could assemble the board, observe that relays are triggered at delay, and think, this thing works, but it doesn't, no protection from dc, unless you make your own gnd to gnd.
I wonder how many amps this thing sits in, and doing nothing else but delay speakers.
Got a look at and board just now, with the new ground wire, I can trigger the relays with my signal generator, triggers at an offset of 1.5 volts, so it works, I'm happy..
Tried working down on low hz, 2hz no trigger, 1hz , red and green light show
Reactions: chrisng
Hello.
Yes it is mounted in chassis now and taking ground from the two 10r resistors ( one for each psu ground )
Its tested and functioning.
But I ask myself why didn't they put a ground pin to the pcb in first place, can see they sold some more than a few, and I bet it is installed in some amps without ground, and only working as delay, removing pop starts
The answer is Negligence. Period.
I've seen, and bought, a headphone amp board that missed a filtering capacitor after the bridge rectifier for its auxiliary power supply, and the ripple current went all the way to the far side of a three-terminal regulator, sharing a return path on the PCB with the headphone output return Ground, back-driving a 120Hz hum into the phones directly, laud and clear!
Reactions: amplidude
