How to measure SS SJEP JFET's
Thank you, the product summary is where the names come from. I'm going to reread how to measure JFET's a couple of times before I attempt this.
Using your example above, I would use a 20 ohm 5w resistor on the drain, a power supply of 10.5 VDC?
