Dear All,
My Nad C316BEE is broken : it does not turn on !
To fix it, I am looking for the schematics ( service manual ).
Of course there is service manual online, but for only the initial version.
Mine, version V2, has the Main VM3.0 card, with a different diagram.
Also totally different the POWER SWITCH board.
Without these diagrams, I do not know how to repair ( possible that it is problem with +5volts lost ? ).
If any of you had the diagrams ( sm will be the best ) for this V2 version...
And if he agrees to communicate them,
I will be eternally grateful to him !!!
Raymond
( pardon me for my poor English, I am French )
Raymond
On the start up circuit board check D63, P6KE200A unidirectional transient voltage suppressor to ensure it has not gone short.
The start up circuit board provides the 5 volt signal to the microprocessor.
If the board is not providing 5 volts the Amplifier will not start up.
Dear,
Thank you very much for your reply and advice.
I just tested D63 : it is OK !
Yes, you are right, it is on this Power Switch board, - and only for this V2 version of the C316BEE ( with MAIN board Vm3.0 year 2012 ) - the +5v is made
Unlike the V1 version, where the +5v was produced on the MAIN board ( Vm1.0 year 2010 ).
In my case, +5v is dead.
The only service manual available is dedicated to first version ( MAIN board Vm1.0 ) .
So, I don't have the diagram for my V2 version, that means impossible to understand !
To try however, I have already changed ic62 ( TNY274PN ) and ic61 ( PC817C ) on the reverse side : without success.
Now, I am out of ideas !!!
Raymond
ps : reverse side of Power Switch board
There, I just found the NAD M50 SMPS board diagram : I think this diagram would be very close for the C316BEE ( that I am looking for ! ) and used to create the +5volts.
The components numbering is of course different on the C316BBE Power Switch.
What allow me to understand a little how it works !!!
And hope to help me...
Raymond
Raymond
You can find the service manual at https://audiocircuit.dk/
With schematics
But I'm afraid that is the version 1
With schematics
This is the C316 V2 Power Switch Circuit
You are absolutely the Best !
And thanks a lot !!
With your help ( this V2 diagram ), and if I am not a complete idiot, I should be able to... ...
Raymond
Thanks to AUDIO-SERVICE, and with the help of its diagram...
the Nad is repaired.
It was necessary to change D63 ( D63 = diode P6KE200A ) : this was the culprit.
Again, thank You All.
Because without your help, I think, I would not have been able to finish it.
Raymond
Raymond
- NAD C316BEE - V2 version ( schematics ? )
