I am building mono block amplifiers, so i had to snap off the left and right side of the universal PSU board. In this case
thanks
- which is the V- and the ground on the left board, ?
- which is the V+ and ground on the right board ?
thanks
You should be posting your questions where you were originally. The UPS build guide here UPS Build guide.
Dan
Dan
