I need to identify who makes the NAU25 3" Full Range Driver aluminum driver cone that is Fully shielded, high-density neodymium magnet oversized voice coil in high tolerance gap to create strong, highly focused magnetic field.
Frequency Response: 120 Hz - 18 KHz
Efficiency: 89dB
Power Handling: Up to 125watts
I need to replace some of them but cannot find who makes them or where to buy them. Any assistance will be sincerely appreciated.
Thank you,
Efficiency: 89dB
Thank you,
