Old school earthquake
I have an old school earthquake 6 channel amp (power house) that has two channels down.
Power supply section is good so I removed the D998/B778 combo on one of the bad channels to find the input is negative rail volts. If I put a 50hz sine to the RCAs for those channels I get a 50hz square wave at the removed transistors input (Full rail voltage) and when stopped its sits at negative rail volts. I cant find the schematics for the board and Im just starting out in amp repair as a hobby, so any help is greatly appreciated.
Thanks guys
Both channels have no sound, they are channels 1 and 2 and are run from the same RCA input. I have now replaced the B778/D998 pair and have the following on each pin.
Base - a square wave from Neg rail to 0v when a sine is applied to the RCAs or Neg rail v with no signal applied
Collector - Neg rail or positive rail (D998 + and B778 -)
Emitter - B778 has the same square wave as above when signal is applied and Neg rail v with no signal. D998 has a small top half of a sine with a signal applied.
