SOLD
For sale is my stereo amplifier based on Hypex NC502MP. All connectors on the back panel are quality parts by Schurter (IEC), Neutrik (XLR) and Cliff binding posts, which allow using banana plugs or bare wires, internal speaker wire is 4Connect 2.5mm2 OFC. Listened to it for < 100 hours with underpowered bookshelf speakers (ATC SCM 11) so it was never pushed near its limits.
Only XLR inputs are wired because I don't have any unbalanced sources but you can just use RCA to XLR cables or resolder the custom input PCB to use the Neutrik RCAs that are already there if you don't have balanced outputs on your source.
The Hypex module itself is bolted to the aluminium chassis bottom lid and thermal paste is used between the module and enclosure. The enclosure itself is the ModuShop(Hifi2000) Galaxy Maggiorato GX283 which looks and feels solid. It is made of black oxidized aluminum with a 10mm thick face plate and allows for effective heat dissipation.
Dimensions: 230 (W) x 86mm (H) x 245mm (D).
Price: SOLD
Price: SOLD
