1U or 2U speaker ?
hello,
look for "best performances" speaker for 1U or 2U rackmount, like this :
any reference ? thanks.
Search Parts Express or US Speakers for small full frange speakers, not woofers.
1U means 44 mm so you can fit round up to, say, 38m diameter (nominal 1.5") which is very restrictive, maybe there is a oval speaker which allows for a wider horizontal dimension.
I have tried almost rectangular speakers (with rounded corners) designed for TVs, but they were frankly horrible.
Now 2U 88 mm will allow up to 75-80mm speakers, Faital and others have good option there.
Whatever you find, you can put two side by side, specially in the 1U rack.
I have fit small potable radio/transparent plastic intercom type speakers in Rack power amps similar to what you show, particularly in commerciall gallery distributed music and PA systems, mainly for the benefit of the operator in a different room (or floor 😱 ) so he can keep track of music program, interruptions, etc. , not to actually "listen" but as a sort of acoustic "pilot light", a very modest job.
  • Thank You
Reactions: altec9440
Wohler used to tip the speaker back at a 45 degrees to allow the use of a slightly larger speaker. You will never get a Who concert out of them but if you limit the low frequencies they will play loud enough.
And black magic add angle horn on horizontal device !
I was hopping that speakers used in computers leads to a simple solution for 1U... But I will follow (again 😉) Jim advices with a TDA2030 amplifier and a 80mm speaker.
By the way, do studies confirm that round speakers are better then elliptical ?
