Tweeters Reference 3A, SerieMaster, Adande Control
Could somebody tell me which tweeters I need to replace the broken ones?
I can't see the make/type anymore. attached pictures
thanks, Robert
Tto help answer your question could you please give us some dimensions to work with?
What is the diameter of the dome approx. 19or 25 mm?
What diameter of the face plate .
It looks like a Vifa unit at to me , could you also get an image of the crossover components as that may be needed to decide on a suitable replacement one the tweeter is fully identified.
Possibly what remains of the identification label is stuck around the magnet, as the remainder of the label still stuck to the tweeter cutout or fallen off inside the box?
Tweeter looks to be a Vifa D27TG3506 with an older faceplate. Can be swapped over to a new one, but the current offering of this tweeter doesn't sound as good as the older one made in Denmark I'd buy a D27TG35 VC asy from ScanSpeak sold through Madisound or Meniscus for about 40 bucks and replace the Ferrofluid in it too.
Thank you very much for your answer so far!
I can't open the box itself or remove the woofer. It is very tight sealed and the woofers are centralized years ago by an expert when I was still living in The Netherlands.
So I can't see the filter and also can't find any lost labels.
The dome is approx.2.8 mm
Face plate is 10,4 cm
Diameter of inside (magnet) 7 cm
Depth 3.8 cm
Weight 460 grams.
As you notice, I am not an expert. Live in Spain nowadays, to send it to Holland to the guy I bought them from years ago, will cost me a fortune.
Kind regards,
Robert
Hi Robert,
Post Nos 5 and 6 above from Profiguy and information from Picowallspeaker post No 4. provides answers.
If you have steady hands and are a born fixer you can probably remove the damaged dome and clean out the old and probably dried up ferrofluid in the magnet gap. At the same time you may get away with gently re forming the dome as Picowallspeaker suggests.
Alternatively get a speaker repair shop to do this for you.
A search for ferrofluid replacement in a tweeter should get you a pictorial guide on what's involved.
