Rockford Fosgate 1051s need help repairing channel
Hey guys I have a power 1051s on the bench. One channel has different voltages per fets. N channel side has 78V from pins left to right while P channel side has 50V and 48v from pins left to right. All outputs checked out fine none had short. All emitter resistors are in tolerance. Not sure what’s going on with this one. This is the left channel. Any tips appreciated thanks guys!
Did you set the bias pots to the full CCW position?
What do you consider to be excessive current?
Was the current draw immediate or only after a few seconds of delay?
Yes I did before I removed the outputs. I was thinking maybe someone adjusted bias to high. On my power supply it was dragging the voltage down to 8 volts! Yes the current pull was immediate. As I mentioned all 10 outlets had no short. Really strange
Does the bias increase on the other channel when you rotate the bias pot clockwise?
The problem causing the high current draw could be a driver component.
The voltage drop on the power supply doesn't say much without knowing anything about the supply.
Both power supplies on this amp are functional. Yes bias does increase rotated clockwise on the working channel. I put back in 9640 attempted to power up amp pulls current automatically with only half the outputs in. They are also heating up. Any ideas? I’ve checked A06 and A56 even replaced them same results.
