The 10mm nuts are 20mm in height.
https://belmetric.com/flat-head-allen-sleeve-nut-stainless-steel/
I contacted them and they have nothing big enough.The 10mm nuts are 20mm in height.
Thanks...too small also...what I am debating on doing is using a 1/4" threaded rod (3' long), and then if needed get a thin piece of tubing to insert over the threaded rod (I am using 2 1/4" metal sleeves for the exterior look. The 2nd option is to is to use the 1/4 20 ones I have on order, and then either tap the end of 3/8-3/4: allthread rod or find a screw on adapter to convert to from the larger size to the small.
Now I am making 3 of these racks and 2 will be stacked...will a 1/4" allthread be able to withstand the weight, with the rack being 30" wide and deep?
I would be ok with 1/2" all thread, but it still leaves the problem of tapping or adapter for a 1/4 20 cap. I would prefer to use the 1/2" all thread and have the ends turned down and tapped for 1/4 20, but I do not know who can do that.There's larger than 1/4" rod stock, and you may need that. Maybe 1/2" rod would work.
Too hard and expensive to machine the rod. Just make adapter blocks for the interface, maybe 2U height.
But use several 1/4-20 bolts, at least 4 or more, at each place.
Too small??...M8 internal thread is 8mm dia. & 12mm long........nut is 17mm long & 17mm overall head dia.
What dimension is too small when you are using 1/4 threaded rod as M8 is bigger..?
My allthread will be one of the following...3/8", 1/2", or 5/8"... I have found thread adapters that will convert to 1/3" on all of the above allthread rods. The too small part is the top cap...hence why I need to use adapters to reduce the size. I posted a message in my local FB group to see if anyone has the capability of turning down and or rethreading to the 1/4".
- Design & Build
- Parts
- Flat head 1" sleeve nuts
