Series attenuation resistor question
I have an issue with the mids and tweeters being too loud ..., they were part of another set-up and i use them and the original crossover " as is " on my own loudspeaker built . If I add series resistance won't this upset / lower the original crossover points .
I have already added series resistors to both the mids and tweeters , now they are way less fatiguing to listen to ..., the mids are wired reverse polarity so I would hazard a guess that they're second order crossed . Parts are from cheap kenwood 12in three ways . I suppose I should keep the power level down until I figure this out so I don't blow up speakers due to low frequency over-excursion , huh ?
The excursion is not increased when you add a resistor. The frequency isn't really lowered, only relatively...
