Hello Guys hope you are doing well.
I got a pioneer gm-201 and I'm trying to make a cable to connect it from the din 8 pin connector to a newer eclipse cd8443 head unit. I've seen the schematic on the manual and signal are pin 2-5 and 3 is ground they go to the RCA from the head unit
7 is illumination goes to +12?
4 is mute. Maybe to mute cable from head unit or unconnected?
But I'm confused with the swd and unswd cables pins 1-6 . Where should they go?
Please any help would be appreciated
Hello Perry nop it doesn't. I'm attaching picture of the schematic and the connection diagram
On 1 side of the amp there is 8 pin din connector female
On the other side should have been a 17p connector but ti have it soldered
+12
Gnd
Ill
Back up (Wich I don't know if need to go to +12 or not)
1Speaker +/-
2speaker +/-
Thanks for any help
+12
Gnd
Ill
1Speaker +/-
2speaker +/-
Thanks for any help
The diagram I have shows RCA jacks. If you don't have them on your amp, all you need is the signal wires and signal ground in the din. If there is no external remote turn-on line, you will have to include that in the din, as well.
