C caraudioguy2100 Member Joined 2010 2022-11-18 11:24 pm #1 2022-11-18 11:24 pm #1 This amp uses IRF640 for the outputs . Wondering will the 640N’s work in the amp ? P Perry Babin Member Joined 2003 bcae1.com 2022-11-18 11:42 pm #2 2022-11-18 11:42 pm #2 The amps with the 6N137 optocouplers sometimes use the non-N and others use the N-version. The N-version will likely work. You must log in or register to reply here.
