AKAI GX-F91 REC DIFFERENTIAL AMPLIFIER OFF-SET
Any suggestion. I can’t adjust the offset setting in the left channel of the rec. differential amplifier. In SM should be up to `+/-10mV, but in fact the voltage in TP1 fluctuates after fine tuning in a couple of minutes from 5mV to 60mV? Was checked transistors TR,25,26 replaced TR24 and electrolytes C6,7.
