AMP PURCHASED!
Just Like the title says I would like to buy a Whammy and/ or M^3 headphone amplifier.
Build quality is most important. For the M^3, I am fine with additions like a pot gain control, bass boost, fancy chassis etc....
The Whammy builds I have seen are mostly stock which is fine too.
I prefer the OP 627 or 4627-1 op amps and will pay extra to have them installed.
You can contact me here by private message .... or at Head-fi / sacd lover by private message.
I have posted a WTB ad on Head-fi as well.
Turns out there’s a kit for Whammy available…. https://diyaudiostore.com/products/whammy
The OPA627 is a single, you’ll need some kind of single-dual adaptor if used in the Whammy. Will also very much help if the capacitors flanking the socket are mounted on the bottom to make some room.
