Hello,
My 3way Diy speaker is using
Tweeter 6ohm
Mid 6ohm
Bass parallel 2x6ohm @3 ohm
Passive crossover and running time is almost 3years .withen three years
I got problem
1: bass one driver damage
2: using bi amp and bass power amp blow
3: another bass driver damage
4 : last week one tube power amp also damage
I carefully thinking problem isall time from low past driver .
6ohm driver parallel 3ohm loading any effect for power amp or driver .
Can I need to change series instead of parallel?
Pls help me .
Tweeter 6ohm
Mid 6ohm
I got problem
Pls help me .
Maybe. Did you break your amp and it had DC at the output which broke your speaker?
If you go for the series connection you will need 6dB more gain and 6dB more Voltage headroom.
I don’t check before Dc out put for power amp
Now I would like to use F6 power amp for 3ohm load ,it can be damage like previous power amp ?
F6 is only 4ohm and 8ohm load only right ?
Thanks for key in
Thanks for key in
Maybe you measured with a multimeter? A 4ohm speaker would measure 3 ohms.
You can try asking about your F6 in the Pass forums…
