Seas Woofer replacement for KLH Model 17?
I just picked up a pair of KLH Model 20's from an estate sale - so $45 for the pair plus a Fukuyo Audio Coral single that was in the bundle [center channel use by PO maybe? - will investigate this one later] that appear to be in nice condition. Ordering some binding posts to replace the rca inputs. It looks like the 20's are identical to the model 17 in tweeter and crossover with a 4 ohm woofer versus an 8 ohm one in 17's. If they fire up and check out as is, I'll rebuild the crossovers and would like to replace the woofer with an 8 ohm one.
I'm considering a Seas Prestige A26RE4 https://www.madisoundspeakerstore.com/approx-10-woofers/seas-prestige-a26re4-h1411-10-paper-cone/ as an option. Anyone used this driver in a 17 or have inputs on threads for Model 17 updates - including any suggestions on the crossover - as long as it stays within the complexity level of no greater than 2nd order. Thanks
