TDA8954 BTL noise shhhhh hummmm
Hi guys! I solved the problem, what I did was to remove the eight capacitors that were soldered on the board and replace them all by 220 mf capacitors, then I put together a separate source with six capacitors of 4700mf on another board the source is no longer in the amplifier, also in the signal inputs on pins 4 and 5 and pins 8 and 9 placed ceramic capacitors 330 pf with that the noise was much lower and was quite acceptable. ( board model XH-M252)
link site from: https://www.diyaudio.com/community/threads/tda8954-btl-shhhhh-noise.366759/page-2#post-6528051
