Hafler transconductance and power
I am restoring a P3000 Hafler. If I understand well, each channel needs a separate power supply (or separate secondaries) due to the transconductance nature of the design.
From the schematics, it appears that the center tap is 'floating', not connected to ground but to the positive speaker terminal.
Am I reading this correctly?
