Resistor with Alpair 12P
I am new to full range speakers. I am thinking of trying a pair of Markaudio Alpair 12P. On the Markaudio website there are suggestions for different cabinets. If I do it, it will be a back-loaded horn. But 2 of the cabinets that is proposed, shows a version with a resistance in serie (one with 2.2 ohms and one with 4 ohms). It then says as an explanation that "Design includes resistance to artificially raise effective driver Qst and lower Fb".
But what would be the idea in that. I could understand if there was something that smoothed out the frequency curve, but pure resistance just makes the driver less efficient. Often, it is because of high efficiency and the fact that X-over components can be completely avoided that you choose a full-tone unit. What am I missing.
if I'm not mistaken it sounds like he may be referring to the following notations:
https://www.markaudio.com/wp-content/uploads/2022/08/Levante.png
Levante: R1 = 3 x 12Ω 20w
or may be substituted for single 50w (min) 4Ω power resistor
https://www.markaudio.com/wp-content/uploads/2022/08/Libeccio.png
Libeccio: R1 = 3 x 6.8Ω 20w
or may substitute for single 50w 2.2Ω power resistor
or possibly https://www.markaudio.com/wp-content/uploads/2021/08/Juliet-Alpair-12P-classic-DCR.png
Juliet design assumes amplifier with 1/2Ω series R
Scott’s, “so you want a big box" series for the A12pw.
Having played with series resistance i figure it takes more away than it brings.
If you do a reflex i would suggest a proper size box, if you want the bass extention then something like Pensil or Joan.
And given you suggest a horn, you would not need any extra R.
dave
Reactions: mp9
Thanks for the many answers. Yes, it is like mp9 says the 2 constructions I mention.
If I have to conclude on what someone has answered, the resistor is used to get deeper bass when you used a small enclosure. In my naivety, I thought that a resistor just was lowering it all, in contrast if you have a correction notch, you would e.g. attenuated from 100 Hz and up (just as an example), or was more specific and removed some peaks, which a full-tone driver will always have.
Dave, I'm confused, in past post you have said A12p needs a larger box like Pencil (Super Pencil) and Joan, yet I can't recall ever reading of wonky alignments with those boxes. Is the R accounted for in the design/stuffing of A12p Pencil (Super Pencil) MLTL and Joan horn?
Also Dave, Triton Transmission Line 12p box is ~ 32 Liters, am I to infer from what you wrote above that the alignments get wonky? Triton plan sheet has no footnotes about adding R
