I have completed Above/Beyond Quantum Power - it is Harmonic/Frequency Theory. Already proven by 2 independent tests . I have 2 designs from the work. One is the SSG-1 Super Generator and the other is the Power Circuit Amplifier, both work by the same principle.. Is anyone making radio valves ? A large size one would be a good prototype, followed by very large models for bigger requirements. All must be completed under a confidential legal contract for protection and preservation. Original work was for E cars but the new theory and work of 55yrs goes into every sector. This work is where Einstein left off. Amplification factor is 10+........
Nah, hook up with Doc Brown for a Mr. Fusion, just the ticket for charging up the flux capacitor needed for the "Quantum Power" required to make a large "radio valve" glow.
Seriously, if you think you have something really new and unique, you will need a far better description that uses words that make sense in the proper context. A phrase like "Quantum Power" can have various meanings depending on the context, but on the net they seem to be most often used to sell some sort of dubious energy device. Ditto, "Power Circuit Amplifier." Nobody here has any clue what you mean.
"Nobody here has any clue what you mean."
"Including the op"
You know the old adage about letting some chimps bang on the typewriter long enough and you will eventually get Shakespeare.
Maybe we'll get to hear the sounds of Shakespeare on the radio when they get it fixed.
"Including the op"
The OP may have poured Coca Cola into his gas tank. Can't get back to the computer to post again. Stuck out in the Utah desert."Quantum Power" ..... on the net they seem to be most often used to sell some sort of dubious energy device.
I was going to post something about going back to 1955 looking for Doc and getting stuck because the DeLorean wouldn't start, but I looked at his avatar screen and it's more obvious than that.
The OP registered on divAudio for the first time Wednesday morning at 5:14 AM. He made this, his only post, at 5:24 the same day, and was last seen at 5:25, one minute after his post. He has not been back here even to look unless he covered his tracks or used a different access device to read the comments.......we have been trolled, but hey, at least the replies have been amusing. Quantum power? Can it give me 1.21 Jiggowatts?
It's too bad you followed Einstein. He was wrong. There is no such thing, dimension, factor, or whatever you want to call it, short of human imagination, as time. There is no was or will be.
Maybe his new invention went Quantum Singularity and swallowed him up.
The first case of "out of (his) mind, out of sight".
" Can it give me 1.21 Jiggowatts?"
I'd be careful about pushing those __LW6s TOO far!!
And achieving a "Jiggowatt overload."I'd be careful about pushing those __LW6s TOO far!!
I was plotting some curves at power levels a bit beyond what's recommended in the data sheet when I found a gassy tube. I then proceeded to make it a bit more gassy. Didn't melt it though. It's still around here somewhere.
The graph shows real measured data on a good tube. The upper green line shows 940 mA at 650 volts at -10 volts on G1 and 150 volts on G2, just a bit over 40 watts of plate diss.
Who needs quantum power when you have BAST's?
So the Secret Sauce revealed at last.
Turn a 12AX7 into a Quantum Power Tube!!
Put some of this on your tube amp tubes to get a real FIREBALL upgrade.
( Don't try this at home! a STUPID DANGEROUS SMELLY idea )
How many idiots are going to put that Hot Sauce on their tacos? At least it will lube the stuff when it comes out! Especially if it’s a high speed rectal fire!
In that case, a rinse and run toilet is a better idea than a conventional TP rig. Toilet paper is flammable. Built in fire department. I wonder what the Flintstones used, they never addressed that. Caveman toilets? Wilma! we are out of rocks.
How do you flush rocks? Where would they go? They have to be round. Another question unanswered and we're talking about secrete quantum stuff. You can't see it right? I'd worry about Fred and Barnies septic tank location first.
- Tubes / Valves
- Power Amp/Vacuum Tube
