LFQA Member Joined 2022 2022-08-31 8:42 pm #1 2022-08-31 8:42 pm #1 Testing to see what value of a Screen resistor works the best... E egellings Member Joined 2010 2022-08-31 9:20 pm #2 2022-08-31 9:20 pm #2 Be sure to use a fusible-type resistor--one that fails open upon overload without causing fire or arcing damage to nearby components. LFQA Member Joined 2022 2022-08-31 9:48 pm #3 2022-08-31 9:48 pm #3 Thanks, but the research is to find what value of resistance works the best. Bugera uses a 680, Marshall 100 or 1k but the old specs use 1500 - 5 k. So far 2-3 seems best... see graphs - so what do others Tubes require ? that is our test Cj You must log in or register to reply here. Share: Facebook X (Twitter) LinkedIn Reddit Pinterest Tumblr WhatsApp Email Link
