If a solid-state amplifier uses transistor circuits to convert an electrical signal into an audio wave.
Can this method be converted to vacuum tube?
You can use tubes to amplify a signal, but you can not pull a transistor from a circuit and plug in a tube with no orther changes. That will not work.
Each type of device needs its own design solution.
Jan
Jan
