6X4 LTSpice Model
does anyone have LTSpice (or similiar) models for the 6X4 Rectifier Tube?
I want to simulate a PSU. Duncan PSU Designer can simulate it. But I want to understand how a PSU is behaving if I use Diodes in parallel e.g. used in Kondo Amps.
Duncan has some Rectifier Tube Models but 6x4 is not included.
Any Ideas for sources?
Thx and cheers
I'm not sure where Duncan derived rectifier model, but it's SS model with parameters adjusted to suit tube IV curve, there is a 6x4 model.
These model is converted to LTSpice model from Duncan's web site:
.model GZ34 D(Is=1e-2 RS=36 Cjo=30p vj=2 N=80 bv=1500 mfg=TFK type=vacuum )
.model 6X4 D(Is=1e-2 RS=121 Cjo=20p vj=2 N=256 bv=1250 mfg=RCA type=vacuum )
.model 5R4GY D(Is=1e-2 RS=150 Cjo=30p vj=2 N=305 bv=3100 mfg=RCA type=vacuum )
.model EZ81 D(Is=1e-2 RS=53 Cjo=5p vj=2 N=163 bv=330 mfg=Mazda type=vacuum )
But alternatively you can derive LTSPice model directly from original IV curves using ".subckt" rather than ".model", as posted by me here:
https://www.diyaudio.com/community/threads/vacuum-tube-spice-models.243950/post-6229593
You can then have a clearer picture of model and source, other to plot the IV curves and compared with original.
  • Thank You
Reactions: WatrixReloader
