This amp uses IRFP260N for the outputs .
Wondering can I install IRFP4229 just for testing purposes?
Lift the center leg of all of the rectifiers, bridge across R220 on the BD driver board and install new FETs. Then you can check the drive circuit.
Sorry I didn’t have a good jumper on R220
Pic 1 is of Q2014
Pic 2 is of Q2013
Pic 3: is of Q2008
Pic 4 is of Q2007,2009
Q2006 has no drive signal
Scope set up to 2us 5volts/div
Pic 1 is of Q2014
Pic 2 is of Q2013
Pic 3: is of Q2008
Rockford can have some strange drive signals but they generally look OK.
The problem is the loss of drive to Q2006.
Where is R64?
Where is R64?
Is R220 a 10k I removed the jumper amp the resistor fell off the board and can’t find it anywhere
- General Interest
- Car Audio
- Rockford Fosgate T2500.1bd
