I Just want to express my gratitude for how great this driver plays into my TL that was designed for eikona. Time ago eikona was replaced by tang band and now with Pluvia. Not designed for the pluvia but i am speachless how good It Is developing in terms of nuances and delicacy.i use them for vocals+Guitar music and i dont Remember a driver giving me such a pleasure .next week a wood builder Will delivery a pencil speaker to accomodate maop 11.2.
Not sure It can sound Better thanx this pluvia but Hope Is high.only then i Will know if the actual pleasure come from the special voicing of the pluvia (jazzy?) or what..Will report back of course...enjoy and as a disclaimer i am not connected at all with MA team
I would expect it to bbe better. P7PHD has a pecular voicing for the Japanese market (similar to CHN-70), the MAOP having a much flatter response which seems to generally be better expected in the west.Not sure It can sound Better thanx this pluvia
The CHN and the 7PHD do wondeful mids...
dave
Thanxs.Probably the wonderful mids make those special....Will see when maop installed in the new speaker
May I ask as to what the differences are between the MAOP 7 and the P7HD? The latter is very good, so must be a bit special? as it keeps cropping up?
MAOP 7 is an A7.3 electron bombarded cone, to create a molecules thick layer of ceramic, P7HD is an A7.3 installed in the newer (nicer) basket with maybe some other tweaks,
Like adding the S (or N or R) suffix to the name of the car to indicate more power et al).
MAOP can be considered sort of like what you would do to puzzlekoat an Al-alloy cone. The !7.3eN does come very close to the M7. AT some point i will have MAOP 7eN, it will be interesting to hear that.
dave
dave
Cheers Dave what is this enabled business. I asked because becoming so enamoured with the P7hd it's hard to see another level again?
Never had the opportunity to do P7HD, here are A7.3eN
I am encourgaing anyone to take uo the pen & brush, and will help as u can. Posts 13, 14, 15, 16 , 101, in this thread give the meat of the technique: https://www.diyaudio.com/community/threads/enabl-listening-impressions-techniques.119676/page-2
Searching you will find much discussion, from no way does this work (lmost always with no audition) to those that can’t live without. It mostrly removes the masking of very low signal/detail, so those listening for tonal change or other characteristics concentrate on the wrong things when listening. It took me an afternoon the first time i got to compare, Now i know what audition material to use an i can pick the EnABLed pair blind in less than 30 sec.
dave
dave
- Full Range
- Mark audio Pluvia 7PHD After 150 hrs
