Is 0.2mm thick Mica Insulator sheeting to thick Sanken transistors?
Hello,
I am in the process of recapping my Luxman M03 and have removed the RHS board from the heat sink. My question is I am unable to source the MT-200 mica insulators for the 2SA1216 & 2SC2922 transistors here in Australia however can obtain a 0.2mm Mica insulation sheet (can take up to 500'C) to cut to the required shape. The Mt-200 of the shelf are apparently 0.12mm thick and I would like to know if the additional 0.08mm would cause any thermal issues with the Sankens?
Is it real mica? Or mica-reinforced composition? You can mix mica flakes with binders and make a sheet good for electrical insulation, but does not conduct "through". That's no good for your purpose.
Since mica is getting scarce, the several products like Keratherm may better today.
Who is your online electronics parts supplier? What country? They should have transistor mounting bits.
If you didn't get "composition", I'm not going to re-quote the entire post for your understanding. Let it go.
Exactly which part of my statement was incorrect? The insulator conducts heat but not electricity. Your wording was not very clear if you are trying to get a concept through to the original poster. I guess you just know so much that you can’t help but try and belittle others. Sad.
