Hypex NC502MP NCore
SOLD SOLD SOLD SOLD
Gently used NC502MP $200 obo+shipping and PP fee.
from the hypex website:
Specs
Technique NCore
Power (2Ω) 2X 450W (not advised to use in BTL)
Power (4Ω) 2x 500W (1x 1000W in BTL)
Power (8Ω) 2x 350W (1x 1200W in BTL)
Channels 2
Weight 1055g
Dimensions mm 230*115*47
Mains voltage input 230V / 115V
Automatic input voltage selection Yes
Description​
The NC502MP amplifier module incorporates a low power standby power supply (meets 2013 ERP Lot 6 0.5W requirements), a highly efficient switch mode power supply and a high-performance Class D amplifier in one compact and easily applicable power brick.
The amplifier used in the NC502MP is a self-contained high-performance class D amplifier intended for a wide range of audio applications, ranging from public address systems to ultrahigh-fidelity replay systems for studio and home use. Chief distinguishing features are flat frequency response irrespective of load impedance, nearly frequency independent distortion behaviour and very low radiated and conducted EMI. Control is based on a phase shift controlled self-oscillating loop taking feedback only at the speaker output.
The main SMPS providing the power for the amplifier is a compact, high power, highly efficient, regulated half bridge converter with synchronous rectification on the main output rails. These properties make this technology ideal for powering Class D audio amplifiers.
For applications requiring a standby mode, a low power standby SMPS also has been integrated into this product. To achieve universal mains input compatibility this SMPS features an automatic input voltage doubler.
The Hypex Channel Extension connector provides for an additional low power tweeter amplifier channel.
APPLICATIONS:​
  • Monitor loudspeakers for recording and mastering studios
  • Audiophile power amplifiers for professional and consumer use.
  • Public address systems
  • Active loudspeakers
FEATURES:​
  • Two channel amplifier
  • 5W standby SMPS
  • Advanced over current protection
  • External controlled operation
  • Auto-switching (115/230V)
  • Low weight: 1055g.
  • Compact: 230x115x47mm
HIGHLIGHTS:​
  • High efficiency
  • Universal mains operation
  • Flat, fully load-independent frequency response
  • Low output impedance
  • Very low, frequency-independent THD
  • Very low noise
CONTENTS OF PACKAGING:​
  • NC502MP OEM module
  • Manual
