Hypex SMPS3kA400
SOLD SOLD SOLD SOLD
From the hypex website:
Specs
Mains voltage input 230V / 115V
Automatic input voltage selection No, Selectable with jumper
SMPS Voltage +/- 2*65Vdc
Max: Output power 3600W
Max: Output power @ 20Hz 3000W
Dimensions mm 200*145*55
Weight 1,5 kg
Description​
The SMPS3k Power Supply is a 3000W high efficiency switch mode power supply specially designed to be used in combination with our range of UcD and Ncore amplifier modules.
APPLICATIONS:​
  • Supply for single or multiple amplifiers of the UcD™ and Ncore range
  • Active loudspeakers
HIGHLIGHTS:​
  • High efficiency
  • Selectablel input voltage range
  • Low EMI
GENERAL FEATURES:​
  • Advanced over current protection
  • Remote controlled operation
  • Low weight
  • Compact
  • Fixed output voltage (2 models available)
ELECTRICAL FEATURES:​
  • High Line Input Voltage: 180-264Vac
  • Low Line Input Voltage: 90-132Vac
  • Output Voltage: 2x65Vdc
  • Max. Output power: 3600W
  • Max. Output power: 3000W @20hz
  • Switching Frequency: 100kHz
MECHANICAL FEATURES:​
  • Weight: 1,5kg
  • Dimensions: 200mm x 145mm x 55mm
CONTENTS OF PACKAGING:​
  • SMPS3kA400
  • Manual
RECOMMENDED ADDITIONAL PARTS:​
  • Cable set SMPS3k
RECOMMENDED AMPLIFIER COMBINATIONS:​
  • UcD250LP OEM
  • UcD400LP OEM
  • UcD400 OEM
  • NC500 OEM
