Speaker Drivers (Some Free)
Joined 2000
10 Qty - Peerless 8" W8-12T 12PS (Free)
4 Qty - Dayton Audio 10" RS2700S-8 ($5 each)
Buyer pays shipping and paypal.
Local pickup ok.
Vince
Wayne PA, USA
Peerless India W8-12T 12P 8" Paper Cone Woofer 12 Ohm
Well-made, attractive, and efficient 8" woofer that will work well in vented or closed box systems. Buyout, limited quantities. Specifications: *Power handling: 40 watts RMS/80 watts max *VCdia: 1" *Le: 1.93 mH *Impedance: 12 ohms *Re: 10.9 ohms *Frequency response: 40-3,500 Hz *Fs: 43 Hz *SPL: 91.5 dB 1W/1m *Vas: 2.7 cu. ft. *Qms: 2.57 *Qes: 0.72 *Qts: 0.56 *Xmax: 2 mm *Dimensions: Overall diameter 8", Cutout diameter 7-1/2", Depth 3-1/2".
Product Details​
Brand
Peerless India
Model
W8-12T
Part Number
299-068
UPC
844632084492
Unit of Measure
Each
Weight
5
Product Specifications​
Nominal Diameter
8"
Power Handling (RMS)
40 Watts
Impedance
12Ω
Frequency Response
40 - 3,500Hz
Sensitivity
91.5dB 2.83V/1m
Voice Coil Diameter
1"
Thiele-Small Parameters​
Resonant Frequency (Fs)
43Hz
DC Resistance (Re)
10.9Ω
Voice Coil Inductance (Le)
[TD]1.93mH[/TD]
Mechanical Q (Qms)
2.57
Electromagnetic Q (Qes)
0.72
Total Q (Qts)
0.56
Compliance Equivalent Volume (Vas)
2.7ft³
Maximum Linear Excursion (Xmax)
2mm
Materials of Construction​
Cone Material
Paper
Mounting Information​
Baffle Cutout Diameter
7.5"
Depth
3.5"
