How do you sell used tubes without a tube tester to be able to include some claim of their current condition?
Either inexpensively or you find a tester in your area and you pay for the results (usually). There are also visible signs that the buyer may want to review before closing any deal.
Or sell them on a trial basis, returnable within 30 days.
What kind of tubes, brand and number, do you have?
I generally sell used tubes in large batches for low prices, most tubes are not worth my time to test. Some types I do a filament/heater continuity test, mostly types my tester does not support. New Old Stock tubes I offer money-back if they do not meet original specs. Some types I do test.
Any tube can easily be tested with a fixed power supply for plate voltage, an adjustable power supply for grid voltage and couple of universal meters.
Actual tube tester is not needed.
I only have a small tote of tubes that I have no plans to use in the future. Some old 6550s, EL34s and a few little ones and a couple new ones; nothing especially rare or crazy valuable. Most have getter that is fading. Probably not worth hassling with at this point; although it would be fun to have the money to play with elsewhere. Someday I should pay someone to test them and get the specs before I forget I have them.
Thanks for the input on it.
More than likely but the chance of selling them for $2 or some other piffling sum is there, which is vexing.Put them up in a lot as untested with a starting bid of 1$ plus shipping... You'll sell them.
The only way to make sure you get a reasonable price is to test them, an emission test will do as artosalo points out. Five minutes with a soldering iron a few transformers and other bits and pieces & Bobs your proverbial Uncle. That or stick em in an amplifier, an easy way is to tack a 10 ohm resistor between the OPT and anode/plate. Read off the voltage divide by 10. List test conditions on your description.
Andy.
They could just start the auction at the lowest price they will take for them and see...
Here's what I'm walking about: https://www.ebay.ca/itm/334489458830
There are 6 hours left and it's up to 89$USD. I'll check in again in the morning to see what the selling price was.
ECC83's and EL84's on the top of the pile, DH97's and PCH81's on the bottom.Put them up in a lot as untested with a starting bid of 1$ plus shipping... You'll sell them.
- Tubes / Valves
- selling used tubes without a tube tester
