Hi!
I'm building a enclosure for my Tang Band W8-740P. Does anyone have any experience with double bass reflex enclosures. This is for studio use and it will be a downward firing bass. I have unlimited space for it. I would like it to be able to handle between 20 to 100Hz. 30 to 80Hz also works.
Link to TS Parameters:
http://www.tb-speaker.com/products/w8-740p
SD: 220cm²
SD: 220cm²
Did you use this driver. was keen on knowing cause I have 2 drivers and want to explore what best to use.
