Is there any interest in Belden 20ga solid and 22ga stranded wire in the group? I uncovered a box of 100ft rolls on metal reels yesterday. Looked it up and it is going for crazy money. Trying to thin my stuff out and get "something" for it. Any thoughts?
Belden must offer a hundred types of each. Newark lists a dozen orderable Belden #20 solid: bare, tinned, Nickel-plate, enameled, PVC, Nylon, THHC, THC, each in red, green, blue and violet/mauve stripe. The factory has, or has made, more choices.Belden 20ga solid and 22ga stranded wire
Unless you found something 'magic', for most of us it is expedient to pull-apart CAT5 network cable.
List some photos, the part numbers, and lengths in the swap section, and see.
Use ebay to get the most money for it.
Will do...most are 100ft spools with the Belden plastic wrap in place. Belden #s....8524-100 (22ga stranded), 8529-100 (20ga solid)..will check for others and take pictures.List some photos, the part numbers, and lengths in the swap section, and see.
Cat 5 is bare 24ga in 4prs 8colors total . Your choice I guess. There used to be a standard EIA color code for hand wired electronics. To restore it right you have to do it rightBelden must offer a hundred types of each. Newark lists a dozen orderable Belden #20 solid: bare, tinned, Nickel-plate, enameled, PVC, Nylon, THHC, THC, each in red, green, blue and violet/mauve stripe. The factory has, or has made, more choices.
Jeez, that Belden stuff is $90 - $100 for a 100 foot roll at distributors. Unlikely anyone here would be interested.
Something about the industrial supply chain, no doubt. Ebay sounds best for this.
This wire is much cheaper.
https://www.remingtonindustries.com...xWT5DEwwJvwxtaqv_XU7Bf9jd8sWam4xoCXfAQAvD_BwE
https://www.amazon.com/TUOFENG-Wire...t=&hvlocphy=9018882&hvtargid=pla-897422432079
When I saw those prices I couldn't believe it. That's why I posted this thread. I have about 30 rolls!Jeez, that Belden stuff is $90 - $100 for a 100 foot roll at distributors. Unlikely anyone here would be interested.
This is much cheaper.
The Remington is a lot less but origin is not noted. The amazon stuff is Chinese so it doesn't look like the original wiring of the 60s. Thanks,for the info
I like ebay but the costs involved are bad on both ends...and I would get a 1099 to boot. I would rather sell it to someone here .... not looking for a killing...something good for both sides.Keep it factory sealed, with the original labels. Ebay is the place.
There are other forums besides this, and places to sell other than e-bay.
Look them up.
Paypal charges about 10%, bear that in mind.
Shipment, I found our local Post Office is the most economic, fast, reliable, and they deliver everywhere in India. Most couriers do not do that.
You need to check that out as well, if you need to ship it.
Look them up.
Thanks for the infoThere are other forums besides this, and places to sell other than e-bay.
Look them up.
- Design & Build
- Parts
- Belden hookup wire
