Audio App for iOS or Android with Time Alignment
Hello everybody,
I'm searching for an smartphone app where you can set a time alignment function for one channel.
Like in the Windows-App EqualizerAPO where you can simply setup a config file with "Channel L Delay = 1,5ms"
and then everything produces an audio output will be delayed for 1,5ms on the left channel.
It is important that the manipulated output will be directed via bluetooth.
Thanks a lot.
Greetings,
Robert
